Bernarticle & smart folder (Beschreibung)
  • Hallo Zusammen,
    ich habe mit smart folder folgendes Problem wenn der Smart folder Datei auflisten soll
    dann taucht die Beschreibung von Artikle aber nicht von die Datei pdf oder doc (Bernarticle) also wie kriegt man das hin dass die Beschreibung von die datei angezeigt .
    <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en"
    lang="en"
    metal:use-macro="here/main_template/macros/master"
    i18n:domain="plone">
    <div metal:fill-slot="main">
    <metal:main-macro define-macro="main">
    <div metal:use-macro="here/document_actions/macros/document_actions">
    Document actions (print, sendto etc)
    <h1 tal:content="object_title" class="documentFirstHeading">
    Title or id
    </h1>
    <a href=""
    class="link-parent"
    tal:define="parent_url python:here.navigationParent(here, template_id)"
    tal:condition="parent_url"
    tal:attributes="href parent_url"
    i18n:translate="go_to_parent_url">
    Up one level
    </a>
    <p class="documentDescription"
    tal:content="here/Description"
    tal:condition="here/Description">
    Description
    </p>
    <metal:listingmacro define-macro="listing">
    <tal:foldercontents define="contentFilter contentFilter|request/contentFilter|nothing;
    limit_display limit_display|request/limit_display|nothing;
    more_url more_url|request/more_url|string:folder_contents;
    contentsMethod python:test(here.portal_type=='Topic', here.queryCatalog, here.getFolderContents);
    folderContents folderContents|python:contentsMethod(contentFilter);
    use_view_action site_properties/typesUseViewActionInListings|python:();
    over_limit python: limit_display and len(folderContents) > limit_display;
    folderContents python: (over_limit and folderContents[:limit_display]) or folderContents;
    show_about python:not isAnon or site_properties.allowAnonymousViewAbout">
    <tal:listing condition="folderContents">
    <dl>
    <tal:entry tal:repeat="item folderContents">
    <tal:block tal:define="item_url item/getURL|item/absolute_url;
    item_id item/getId|item/id;
    item_title_or_id item/pretty_title_or_id;
    item_description item/base_href;
    item_type item/portal_type;
    item_type_title item/Type;
    item_modified item/ModificationDate;
    item_created item/CreationDate;
    item_type_class python: 'visualIcon contenttype-' + normalizeString(item_type);
    item_wf_state item/review_state|python: wtool.getInfoFor(item, 'review_state', '');
    item_wf_state_class python:'state-' + normalizeString(item_wf_state);
    item_creator item/Creator;
    item_start item/start/ISO|item/StartDate|nothing;
    item_end item/end/ISO|item/EndDate|nothing;
    <dt metal:define-macro="listitem"
    tal:attributes="class python:test(item_type == 'Event', 'vevent', '')">
    <span tal:attributes="class string:$item_type_class summary"
    tal:condition="python:item_type != 'Link'">
    <a href="#"
    tal:attributes="href python:test(item_type in use_view_action, item_url+'/view', item_url+'/');
    class string:$item_wf_state_class visualIconPadding url"
    tal:content="item_title_or_id">
    Item Title
    </a>
    </span>
    <tal:to_external condition="python:item_type == 'Link'">
    <span tal:attributes="class item_type_class">
    <a href="#"
    tal:attributes="href item/getRemoteUrl;
    class string:${item_wf_state_class} visualIconPadding">
    External Link
    </a>
    </span>
    </tal:to_external>
    <span class="documentByLine">
    <span tal:condition="python: item_type == 'Event'"
    i18n:translate="label_event_byline">
    (<span tal:content="string:${item/location}"
    class="location"
    i18n:name="location">Oslo</span>, from
    <abbr class="dtstart"
    tal:attributes="title python:item_start"
    tal:content="python:toLocalizedTime(item_start,long_format=1)"
    i18n:name="start">from date</abbr> to
    <abbr class="dtend"
    tal:attributes="title python:item_end"
    tal:content="python:toLocalizedTime(item_end,long_format=1)"
    i18n:name="end">to date</abbr>)
    </span>
    <tal:byline condition="show_about">
    &mdash;
    <tal:name tal:condition="item_creator"
    tal:define="author python:mtool.getMemberInfo(item_creator)">
    <span i18n:translate="label_by_author">
    by
    <a href="#"
    tal:attributes="href string:${portal_url}/author/${item_creator}"
    tal:content="python:author and author['fullname'] or item_creator"
    tal:omit-tag="not:author"
    i18n:name="author">
    Bob Dobalina
    </a>
    </span>
    </tal:name>
    <tal:modified condition="python: item_type != 'Event'">
    &mdash;
    <tal:mod i18n:translate="box_last_modified">
    last modified
    </tal:mod>
    <span tal:replace="python:toLocalizedTime(item_modified,long_format=1)">
    August 16, 2001 at 23:35:59
    </span>
    </tal:modified>
    <metal:description define-slot="description_slot">
    <tal:comment replace="nothing">
    Place custom listing info for custom types here
    </tal:comment>
    </metal:description>
    </tal:byline>
    </span>
    </dt>
    <dd>
    //Hier muss die Beschreibung von die Datei nicht von der Artikle angezeigt
    <span tal:omit-tag="" tal:condition="not:item_description">
    </span>
    <span class="description" tal:content="item_description">
    description
    </span>
    </dd>
    </tal:block>
    </tal:entry>
    </dl>
    </tal:listing>
    <metal:empty metal:define-slot="no_items_in_listing">
    <p class="discreet"
    tal:condition="not: folderContents"
    i18n:translate="description_no_items_in_folder">
    There are currently no items in this folder.
    </p>
    </metal:empty>
    </tal:foldercontents>
    </metal:listingmacro>
    </metal:main-macro>
    <span class="teaserBlockDescription" tal:content="folderContents">
    Vielen Dank im Voraus
    wishah
