• Das ist der code mail adresse wurde geändert:
    /* General Configuration */
    /* PHPRPG_DIR : Base directory to where the main files are located, without */
    /* the trailing slash '/' (e.g. 'c:/path/to/game') */
    /* PHPRPG_URL : Base URL to where the main files are located, without the */
    /* trailing slash '/' (e.g. 'http://yourwebserver.com/game') */
    /* PHPRPG_MAIL : Appear as the sender's e-mail address on e-mails and */
    /* notices sent to players */
    /* PHPRPG_ADMIN : The password for the root user of the game */
    /* PHPRPG_THEME : What is the default theme for this game */
    define('PHPRPG_DIR', '-);
    define('PHPRPG_URL', '-'); <-- Zeile 17
    define('PHPRPG_MAIL', '-');
    define('PHPRPG_ADMIN', 'password');
    define("PHPRPG_THEME", 'phantasy');
    /* Game Configuration */
    /* PHPRPG_SESSION_EXPIRY : Seconds before automatic session termination */
    /* PHPRPG_EPOCH : UNIX TIMESTAMP that defines the start of time */
    /* PHPRPG_START_MAP : Map ID that the user should be sent when created */
    /* PHPRPG_START_LOC : Location ID that the user should be sent when */
    /* created */
    /* PHPRPG_START_STATS : The number of points that the player can allocate */
    /* when they create a new character. */
    /* PHPRPG_START_AC : The base armor class */
    /* PHPRPG_START_GP : Amount of gold to begin with */
    /* PHPRPG_START_STAMINA : The default amount of stamina a character has */
    define('PHPRPG_SESSION_EXPIRY', '1200');
    define('PHPRPG_EPOCH', '0');
    define('PHPRPG_START_MAP', '1');
    define('PHPRPG_START_LOC', '143');
    define('PHPRPG_START_STATS', '60');
    define('PHPRPG_START_AC', '10');
    define('PHPRPG_START_GP', '1000');
    define('PHPRPG_START_STAMINA', '1000');
    /* Game Log Path */
    /* This is the path to your local error log. If you would like to use this */
    /* file elsewhere on your system, please make sure the webserver has write */
    /* access, or the game WILL NOT FUNCTION */
    define('PHPRPG_ERROR_FILE', PHPRPG_DIR.'/share/log/error.log');
    /* DO NOT MODIFY BEYOND THIS POINT */
    require_once(PHPRPG_DIR.'/etc/init.php');
    Einmal editiert, zuletzt von Emil (26. Mai 2009 um 19:14)
  • Joa, das liegt an deinen Pfaden *gg*
    Zitat
    define('PHPRPG_DIR', 'http://apfelfuss.redio.de/);
    Nimm da mal ./.
    Wenns nicht geht brauchst du den regulären Provider Pfad, der nicht so einfach zu bekommen ist.
    Meistens etwas wie /home/web/www/kunden/abcdefg123456/htdocs/ o.ä.
    Da kann man dir aber nicht genau helfen, da den keiner von uns kennen wird.
